hi i've 2010 saab 93 turbo tid 150 bhp and the washers have suddenly stopped working.... have changed fuses for pump motor and checked the squirters aren't blocked..... no water on the ground and can't see and wires or tubes hanging down.... any input very welcome.....
You probably need a new pump theya re a common fail especially if run dry ....easy DIY...lift edge of wheel arch liner and pull the pump away from the reservoir.
You need part 12782867
Definitely pumps gone
