i have slightly different prob.i have no hot air from my acc.everything else is ok,it blows cold as hell when on auto.but in the morning when it is a bit cooler outside i am getting no heat from system.this has just started and nothing has been disturbed/i have checked the obvious,water level etc.any ideas?
If you have 1990 and beyond try the following:
-see if your cabin sensor is working( it is the little 1inch square black grille)
-see if your ACC system has generated any faults, this is done by holding down the "auto" and the vent button at the same time for 30 secs. It will go blank momentarily then flash the # of errors, finally it will display the previously set temperature. Then it will calibrate itself.
-see if your temp works at Hi setting, your engine temperature shld be close to normal will you do this.
