No boost
Help please.
On the way to the Tamworth meet I lost boost on my 92 2.3T,waste gate is free,all vac lines appear good,solonoid on rad,APC?,changed for supposed good one,still boost gauge will not go into yellow.Has anyone any ideas before I apply 5liters of gas and a match?
Mike
Re: No boost
if you disconect wastgate hose from apc, and take for a spin, do you get full boost, (dont hammer it as it will go to cut off, if it does suspect apc, check fuse and wiring)
any mis firing lately, coule be plug problem, also try re-setting ecu, by disconecting battery leads for half an hour, and doing an adaptation run.
hope this helps
Re: No boost
Try double checking the vacuum pipe from the dump valve, I've been having problems getting full boost lately and my pipe is perished, although looks alright at first glance. The car was only boosting half way into the yellow.
Neil
