Boost probs well documented. Tried various things. No luck.
I want to try different DI and solenoid valve. I live in South Mancs and am visiting parents in Wakefield on Friday, could anyone lend me these for an hour who live in/around these areas.
If you are only getting base boost have you checked to see if you are getting a feed to the solenoid? It should click when the ignition is turned on. I've just cured this problem on my 900 and it was the APC plug not pushed fully home.
Neil
The BPC valve doesn't actually click like the earlier APC solenoid. It will hum quietly with the ignition on if working properly, though. It's also worth mentioning (while I'm on the subject) that the Saab documentation warns against trying to test the BPC valve by applying battery voltage to it, as you might with an APC solenoid. The BPC valve doesn't work in the same way.
