Thinking about getting a standalone ECU and I'm trying to work out if it's worth getting a wideband sensor or just sticking with the supplied narrowband setup. I can get the wideband added on later if I miss it - but I don't really think it'll be necessary ??? I don't really know what the difference is?
Wideband is necessary when tuning a turbo car. Narrowband O2 sensors do not have enough range to differentiate a 12:1 AFR, from a 10:1 AFR accurately. They also don't have much range in the lean section. Normal O2 sensors generally can only tell rich from lean, and locate stoich for naturally aspirated cars.
Dubbya~
The sensor reads the exhaust gasses, feeds it back to the ECU and the ECU adjusts the mixture (or something) - you need one on your car if you've replaced your ECU with a different one.
Pete - I think the sensor would be permanently fitted into a mounting point on the exhaust (like the standard one) so I guess it wouldn't be right to borrow one and keep it I don't have much knowledge when it comes to the more technical things so I could be wrong about this. I think the device stays on the car and the Motec constantly uses it as your driving around.
