Hey guys,
For the past few months, my 2.3i automatic has been making a strange noise when below about 1000 RPM. It doesn't matter if the engine is warm or cold; whenever the RPMs drop below 1000 (like around 900 for a normal idle speed), I can hear a "purr purr purr" noise coming from the engine. I can also feel quite a bit of vibration through the steering wheel (more so than usual!).
I've looked at the engine while running, and when the revs are below 1000 RPM, the engine block appears to shake a little. A mechanic told me the noise and vibration is coming from the AC compressor, but it's not on, and hasn't been in a few months. I saw him put a large screwdriver between the engine and compressor, and the noise appeared to stop. He said he'd put in some spacers (after failing to be able to further tighten the bolts on the compressor).
Anyway, back to the sound: it sounds like a cat purring, or maybe even the sound that a Scottish person might make when pronouncing the letter "R". (Think groundskeeper Willie here )
Could my engine mounts be gone or going? Or could it be just a problem with the compressor mounting?
I'd rather it be the compressor mounting, since that seems like a much cheaper thing to fix...
