I replaced the multirib on my 2.3T last May because the old one was showing signs of cracking. 2 months later the belt came off the pulleys When putting it back on again it was apparent that the water pump bearing was worn allowing the pulley to slop about which had probably allowed the belt to rise up and work it's way off. I fitted a new water pump.Another 2 months later the belt broke.
One of the ribs had come away, wrapped itself round the alternator pulley and jammed the belt which broke. I assumed the belt had been damaged when it came off the previous time and fitted a new one.
This weekend, once again the outer rib has seperated from the belt, luckily coming away without snagging anything this time.
When I replaced the belt I also replaced the pulleys but I didn't replace the hydraulic damper. Seems to me that maybe I should have. Any one have any ideas about this?
