does anyone have any experience of modifying the T16S APC unit as detailed on the 900 AERO website. I have no problem with doing the actual electronic components, would like to know what the improvements are like and how easy it is to set up (adjusting the pots etc.).
If you are just adjusting the pots P & F then all you will need is a multi-metre to read the ohms & kohms..
once you have done it once or twice then it only takes 5 minutes to unplug, remove the APC unit.. take the top off & adjust the pot settings & put every thing back together & drive of for a test flight.
results are very good with just pot adjustments...
I'm now running with higher P & F and replaced resistors etc etc
& very happy with the results that I'm getting
Paul
p.s. Welcome to Saabscene
I have modified the APC in my '87 9000 Turbo, to a custom mod of dash mounted boost controller, from 5 psi - 18 psi with full knock detection and no boost fade. replaced resistors, bypassed some, etc... I have some other mods listed here, and the procedures! if you want them, PM me
