hi,
i just pulled apart my APC box, and found a couple of things different to what i have read is described in it....
"F", "P" and "K" are supposed to be pots in the APC guide i have... all i have is P01 P02 and P03.. i am wondering if anyone knows which number coresponds to which letter??
thanks for that.. got the APC modded now... and there is a lot of
torque steer in 3rd gear now...
lol Just a note about that second part there. I've not tried this out myself, but the "duration" part labeled there I believe is actually "boost climb rate". At least that's what I was lead to believe at the 900 Aero site. Which makes sense. You hafta adjust that setting to as high as you can without any boost spikes. Hafta look into that sometime, see if it's indeed climb rate and not duration. Has anyone else here experimented with it to see which it is?
in the guide i have, that "F" (the one labeled Duration) is actually the boost curve, and adjusting that gives the defined curve of the boost.
