Could someone please do me a favour?
If you have an ETS/TCS equipped car, could you please have a look under the throttle body at the air filter end of the body.
There is a small stub sticking out that should have a vacuum hose attached to it. Could you please follow that hose and tell me where it goes?
I know it sounds strange, but I have no hose on mine and try as I might, I cant find the errant hose.
It must be there somewhere (hopefully)!!!
I think (too)high levels of boost may have blown it off!!!!!!!!
Have a look at my post pipe work pete,my 91 carlsson that i have, felt a little off power to me when i brought her,found a pipe lose under the throttle body,which i thinks goes on the stub you can see,the dump valve has a vac hose on it you should be able to trace this too and past the battery,it will join about 4 other vacum pipes which all end up on the wheel arch at the side of the battery joining up to some kind of switch.
stu
