Morning and welcome.
any idea why two of the new plugs are so corroded around the base? for them to corode like this means water/coolant/fluid is getting on them, possibly running down the coil pack - fluid will flow to the lowest point and the whole of the base is corroded. two of the coil packs are also showing signs of water damage. water and coil packs do not mix.
Might be plug or coil pack playing up but i would find and sort the source of the leak first as this is the likely cause of your problem.
