Tonight after fitting a 20p axle end (button) to the waste rod on the Aero I decided to try fitting a MBC between the W port on the APC and the wastegate to keep It clamped firmly shut until a low preset value (about 7.5psi) for a quick spool up.
It didn't work Horrible overboost spikes up to 20psi and safety cutout. from about 2500rpm, no APC control at all. I ended up undoing the adjuster until it came out and I could blow straioght through it.
Get the revs up a bit higher though 3500+ when boost and APC are normally up and running, and the boost it stable at 15psi as normal and controlled (apparantly) by APC.
Any suggestions?
Should I plumb it another way? I'm keen to keep some APC function.
PS. backing the throttle off to keep 20PSI, the car sure fly's
Any suggestions?
