1 - 13 of 13 Posts
Premium Member
I'm after a 40a feed and there's a spare 40a maxi slot for electric seats which I would like to utilise
Anyone seen a maxi fuse tap in the UK?
I can only find mini or micro versions
Anyone used any other methods?
Premium Member
Discussion Starter #3
What do people think 6mm (10awg) or 10mm (8awg) thinking 30-50cm cable length
Old setup I knew it had to be 0awg due to needing 300a, almost had to upgrade to 00awg as that was pushing a 5m cable but when I bought my setup which must be almost 10 years ago 0awg was the biggest I could find in the UK
Premium Member
anyhow providing you can make space,as I think you will struggle to find what your after, and if your not wanting to tap in at the rear of the fuse box my suggestion wold be.......
cut out a full blade from a maxi fuse solder on cable and heat shrink, push the blade in the +12v terminal
fit a midi fuse and holder in a convenient position http://www.ebay.co.uk/itm/1-x-MIDI-TYPE-CAR-TRUCK-MARINE-IN-LINE-FUSE-HOLDER-WITH-40-AMP-MIDI-FUSE-/321685977099?pt=LH_DefaultDomain_3&hash=item4ae5fa780b
or use a agu style circuit breaker fuse if its for what im thinking its for
other than that would be to solder a cable to the cable +12v at the rear of the board or use this cable to supply a new 4way standard fuse holder if more fuses are required obviously these would require more work
is there power at the fuse with ign off something worth thinking about if required permanent source
Premium Member
Discussion Starter #7
It's only for a small 500w amp I have knocking around to run some 6x9" it a 4ch so going to bridge it to make it 2ch should be about right power as they are sub drivers
Already cut down a maxi fuse just trying to aquire some cable
Premium Member
with a loading of 500w over a distance of 0.5mtr you are only looking at 1.5mm so 2.5mm will be more than adequate if you want to air on the safe side
Administrator
unless they've changed the config of the REC,fuses #15/16 are for the heated seats @ 15 amps each..i've yet to find any lists for the maxi fuses fitted in the 9-3..
Premium Member
nice one
the reason I mentioned the way I said as to the way you have done it is if the fuse blows you will need to rebodge another fuse lol. although a man of your calibre wont pose a real issue
Premium Member
Discussion Starter #13 (Edited)
If the fuse goes I'll just spin it around and put an in-line on, it will be easier
Used cable & crimps from work ended up using 1mm for remote & 16mm for power
In comparison to my old setup its not really noticeable when looking in the boot :) kinda like it
Tbh Oem wasn't bad and easily went loud enough, change of headunit the biggest difference was in the lower mid / upper bass it cleared it up immensely, change of dash & shelf speakers didn't make that much difference
In comparison to the old system quiet awful sound and changing the speakers made a big difference in quality
Not sure what to do with the door and centre speakers as no point putting my 4ohm focal in
Also on the look out for rear door cards for a böse system so I can fit some 5.25"
1 - 13 of 13 Posts
