Hi all
Just wondered if anyone had experienced anything similar? When accelerating, even going gently with boost in lower yellow, I can feel the power come in surges. It is most noticable when the engine is still cold. Without moving my foot at all on the pedal and with the boost in the yellow I go through a series of flat spots that only even out if I floor it (not what I want to do when the engine is cold) and are much less noticible when the engine is warm. I have tried using an injector cleaner...no difference.
Would it be worth doing a resistance/voltage check of the oxygen sensor/MAP sensor/air density meter/air temp meter/whatever else meter....to see if anything is a little out of kilter?
Or could it be related to my sticky idle air control valve which currently gives a rather eratic idle (or I suppose there might be nothing wrong with the IAC valve and the other 'flat spot' problem is causing the eratic idle???)
While on the subject, I can see how to check the resistance of a component at the pins when disconnected, but how do you check the voltage being sent/received at a given sensor? Do you have to strip back a bit of wire and then tape it up afterwards?
Kev
Kev
