Further to my pre-christmas panic I've now identified the problem with my turbo. The wastegate actuator rod has crumbled and fallen off. I've removed it now with a bit of skint-knuckle-universal-joint-swearing technique. (took me three months to get round to it) I spoke to Westcars, Glasgow who said there are many different parts listed ( they call it a preassure regulator)then said they had all been superceded by one part number, which sounds a bit odd.Cost £187 +vat. Independant specialist in Fife quoted £60-£80 but I need to identify which actuator I've got. there are different spring rates, rod length etc. depending on model and spec. I can't see any numbers on the turbo and the actuator is so corroded it's impossible to see if anything is stamped on it. Turbo specialist says there should be a number stamped on the end of the actuator opposite the rod. Car is a '93, 2.0l, 9000CS LPT, ecopower. I want a standard part, in case anything different upsets my LPG fuelling.
Can anyone help me to identify which actuator I need?
