Was talking to Ed at Abbott the other day, and he brought up the subject of lowering and panhard rods. He said something along the lines of unless you want very wide tyres or lower the car a LOT, then shortening the panhard rod isn't needed. They used to have adjustsable ones on their race cars.
40mm is quite a lot, you may find the rear axle is very slightly offset to one side afterwards.
We had this problem with a Spax spring & damper kit we tried on a 900 many years ago, similar drop in ride height and it meant one tyre was very close to the wheel arch, the other had a half inch gap.
Worst issue with that particular kit (it didn't stay on long) was that the car was riding on the bumpstops most of the time
I presume you plan to replace the worn dampers at the same time? Not a good idea if not...
Does anyone know if the Carlsson has a shorter Panhard rod? The sports springs are shorter so you would hope there was a difference if the above is taken into account.
Maybe there isn't as much difference with the rear springs.
