A good locksmith or a wire hanger and plastic card, use the plastic tool to try and get space between the roof and window, once you have at least 5mm, insert the wire hanger and try and get the door hook thing to pull upwards. It will take a few attempts and you'll have to shape the end of the hanger to fit over and somehow grip the hooky thing to pull upwards. You could also use a piece of string with a hang mans noose and use the window as a lever to pull up
Good luck whatever you do
