Whilst having a look in the engine room I found that the brass union in the throttle body had come away. It's just inside the mouth of the body on the lower surface - seems to be connected to a rubber breather pipe.
On a normally aspirated car it wouldn't trouble me - but this is a 2.3 stg 1 lpt.
As a temporary fix I cleaned everything up with carb cleaner and used a smear of araldite rapid.
I left it for an hour or so, took it for an off boost spin to get some heat under there and let it cure for another hour. Just given it a good WOT run it has held so far.
Any ideas for a permanent cure?
( No better boost now its connected --- but it seems to spin up faster )
Alyn
I've had this problem with the same union (it sounds like it, anyway) on both my 9000 turbo's.
To be honest, Araldite sounds like a good fix, as long as it holds up to the heat. Time will tell!
I used JB Weld (there are a host of similar products, available in halfords et al.), which is fairly similar in principle (2 pack adhesive). On the old one, it was still fine when I sold it 6 months later. On the new one I'm 3 months or so down the line and no problem so far.
I honestly don't think anything more complicated is called for.
While not a common fault, I have heard of this happening on 6 or 7 cars now, mainly with lower or downward nipples (oil ingress??).
I wouls have used Araldite too (but not rapid which can go soft with heat).
Andrew.
Thanks,
I shall get hold of some JB weld and use that if the araldite repair fails. (Should have remembered that about the heat making "Rapid" soften)
- Incidentally the other brass union failure that I know of was on the Reliant Scimitar's webber, later fuel unions were "pinned" - early ones an interference fit. If an early union pulled out the fuel pump sprayed petrol over the engine - the ensuing fire usually led to a complete and very quick total destruction.
Alyn
