The lights on my Aero's climate control switches are out, the ones at the side are ok (telling you whats on) its the ones telling you what they are,rear heated screen, fan speed, etc its ok in the day but imposible to see at night, any tips on how to get to them please.
thanks
Mark
Mark,
There are 4 large bulbs in the ACC, 1 for each column.
To change, pop out the Acc unit. It tapers rapidly to towards the back and plug/s
remove from connector plugs and take inside.
Remove about 6 or 8 small phillips screws of the top rear,
when this is off, you will see 4 1/2 inch round twist out plugs at the top rear of the vertical PCB.
Each one of these has a large almost unobtainable capless bulb (except via saab) that just sits in the holder and has its wire legs wrapped around the plastic bulb holder base.
I did'ne buy the saan ones, and fitted the type of bulbs for the electric door switches. nowhere near as large, and only 2/3 the power, but they work ok and I had some to hand (although the very lowers button is a little dim.
Refit is the reverse of removal.
