I have obtained from a Griffin, leather door trims and the full wood kit.
The problem is that the door cards are in poor condition (stain , marks, ect.), although the wooden cappings and the stitched leather inserts are mint.
My question is: can I transfer the wood and leather to the door cards of my 9000?
The leather inserts seem to be attached using plastic rivets.
I have searched the forum and found nothing.
Help on this matter would be appreciated.
The wood cam be trasferred, but you will need to drill 3 or 4 holes in your door panels to fit.
Also, the rear doo panels come in 2 types, 1 with and 1 without ACC vent holes at the front.
Also, you will need to unscerew the plastic ACC vent from underneath on the little phillips screw at the top of the motor vent trunking.
Finally, the plastic surround for the door locka are 1/4" longer so these need swapping too.
Sorry, I do not know how to swap the leather pads over.
Andrew.
