81 - 89 of 89 Posts
Old thread but still drawing inspiration from it! Couple of questions:
Did you have to have longer wheel bolts when you fitted the spacers? I want to fit spacers with my 18" Ronals as you did originally.
Did you have to spray the aftermarket rear diffuser?
Did you remove the parcel shelf to spray it or do it in situ?
Many thanks
I can answer 2 of your questions Telsun
With the wheel spacers you have to fit the longer bolts I'm running 19" VXR alloys with 20mm spacers
The kit comes with the longer bolts .
Also with most of the after market diffusers ( those from Poland) you do have to spray them . Also a bit of sanding is involved as they are not 100% but the adverts on that well known auction site do state that .
Discussion Starter #85
Hi, my spacers were about £50 and are the bolt to hub type. They bolt onto the hub with the included bolts and then the wheels bolt to the hub using your existing nuts.
The diffuser didnt need painting, it came with a glossy gel coat type finish which has since dulled to a nicer satin sheen.
The rear shelf is held on with 3 or 4 clips behind seat back and then just pulls off once unfastened.
Discussion Starter #86
Also diffuser was a perfect fit apart from the bit i trimmed as seen in earlier pictures
81 - 89 of 89 Posts
