I'm hoping that someone can shed light on this. The car is getting worse. It starts fine every time. When fully warmed up the tickover is 850 ish. It can drop to 400-500 without warning and then go up to 1100. At a steady 70 you wouldn't think there was anything wrong with it. But, say, approaching a roundabout, as foot is taken off throttle, the tickover will drop and there is a lumpiness present. On getting back on the throttle, say in 2nd gear, there is a holding back as if power has been cut by 30% and, after a couple of seconds, it will come back. Two or three times aday the car will stall completely although it will restart easily. The car, though, just does not feel as powerful as it should bearing in mind its not a turbo. The urban fuel consumption drops to 18-19mpg which I feel is bad. Away from the lights I take on no-one - not even scooters as the car just does not seem up to it. If I set the car at 15mph in second with clutch fully engaged and then nail it the pick up is leisurely to say the least.
I have had a new trionic red rail. I had a long time Ex Saab guy with the diagnostic proper Saab computer check it out and the only thing he can find is that the vaccuum is low at 16 instead of 19 - whatever the units of measurement are. Fuel delivery looks OK. Compressions OK and no induction leaks. The car does consume a touch of water though but only about half a litre a month. Apparently this should be none
Are the fuel pumps on these cars reliable. What about the ECU? Anyone have any ideas? If I knew what it was I would have it changed but some of these parts are expensive and at £223 lighter for a DI rail, I could do to get this sorted as I have a long drive in it soon.
Thanks for reading
Thanks for reading
