KSPORT's Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. Made from high quality 6061 Aluminum with T6 for increased hardness.
Kontrol Pro
•36 levels of adjustable damping
•Made from high quality 6061 aluminum with T6 for increased hardness
•Compression/Rebound adjustable
•Adjustable spring perch for height adjustment
•Adjustable body allowing maximum suspension travel
•Pillowball top mount with adjustable camber (not available for some models)
•Monotube high pressure design reduces oil leakage
•Electroplated body for protection from corrosion and rust
•One year limited warranty
9-3 - 2003 ~ 2011 - 1.8T, 2.0T, Sport Sedan, 2.0T Aero, 2.8T Aero - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
9-5 - 1998 ~ 2001 - Steel axle - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
9-5 - 1998 ~ 2001 - Wagon - Steel axle - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
9-5 - 2002 ~ 2009 - Aluminum axle - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
9-5 - 2002 ~ 2010 - Wagon - Aluminum axle - Height/Ride Adj - 36 dampening levels - Fr Pillowball Up Mount / Uses Rr OEM Mount
GT Pro
•Inverted steel shock absorber for durability
•Lower center of gravity and higher chassis rigidity
•Designed to reduce friction for cooler shock oil temperature
•Inverted design like vehicles in WRC and all JGTC cars
•36-way adjustable damping
•Made from high quality 6061 Aluminum with T6 for increased hardness
•Adjustable spring perch for height adjustment, •Adjustable body allowing maximum suspension travel
•Pillow Ball Top Mount w/ adjustable camber (not available for some models)
•Monotube High Pressure Design reduces oil leakage
•One Year Limited Warranty
GO TO NOPI KSPORT Catalog for model specific images and details
Contact the salesmen below or PM me for our best deal on KSPORT Coilover Systems
Hi,
I am very interested in this coilover kit but I have a few questions.
So my car is a 2002 model Saab 9-5 Aero Saloon, I think you call it Sedan, I am not sure if the axle is aluminium or not??
Do you have a kit to fit the above vehicle and if so what is the best price you can do.
