I need to adjust my k/down cable,Haynes show a cable with a threaded end for adjustment,mine has no thread,just a plain shank and clamp,again Mr Haynes states 2.5mm between the cable end and crimped ring,now mine has a plastic seal over the end of the cable.Question is,has anyone any ideas what the measurements should be on my cable,9000 2.3t 92 vintage.
thanks in advance
mike
Hi Mike, I just set the clamp so that the throttle pedal operated the kick down at the bottom of its travel - you can 'feel' a difference on the throttle pedal when the kickdown valve? is being moved by the kickdown cable. I then too it for a spin and everything works fine.
