Hi
I have a 2005 95 sedan and the remote control on the key just stopped working.
The spare key is the same, I changed the battery, still nothing.
I can unlock and lock the car with the key and all the door locks work.
I can drive the car, everything appears to work ok, but the led in the middle of the dash is not on, I cant be sure it was working before the problem started so this may be irrelevant.
My first thought was a twice module issue, but if it was was I would expect other functions controlled by it would not work as well.
Any suggestions please
Have the same problem but bought the car like that.. have the banana remotewhich is not working.. many suggested to press unlock 10 times while in the car to connect it, there are guides on forum how to reconect the remote
Sent from my SM-G930F using Tapatalk
Discussion Starter #3
Thanks for the advice
Thankfully I found the problem, I took my car to a saab gentleman where he found the lock barrel is not popping up correctly, all I need to do is remove it and clean and lubricate it
