Hi
I have stage 3 on the car with stock air filter and air box. Lets say, that the ECU requests an amount of air mass @ 3000rpm, then the turbo will try to boost the requested air mass from ECU. If i modify the air box (take away the plastic inlet pipe where the air enters) and go direct with a briefly 3" pipe to air box then the engine will get more air and the turbo won't have to boost so high in order to give the requested air mass. As result the intake temps will be reduced and in some cases this will allow more HP because of better ignition times and lower intake temps. Am i right?
