My 92' j reg 9000 cdxs is very sick.Its got 155k on the clock and the list of things wrong at the monement is as follows.
Front nearside wheel bearing gone
Both front pads gone(maybe disks to)
Drips oil like a good 'un
No "uumph" any more(darnte ask)
Heater hose gone at the engine end(goes through a header tank a day)
Filler hose gone at the top.
How much do you think to fix?
babpussxyz.
nothing you have listed is terminal,nor over expensive,;
front brake pads £25
pair of discs £50
front wheel bearing ££68,
oil leaks are not that expensive to cure,probably the cam cover gasget,no more than a fiver I would have thought.
Now one of the heater hoses will cost you over £30 the other about £8
I am not sure which filler hose you mean but it will not be expensive.
So it is going to cost you around £200 in parts,a good service by an independant will set you back another £200(and it sounds as if you need it)For around£500 you should have a nice car instead of a trainee shed.
Agreed. None of the things listed is major either in terms of labor or parts. Most, I would think, could be dealt with on your own requiring only a bit of time and patience. The oil leaks will take a bit of tracking but are usually attributed to an o-ring here or seal there. There are a couple more complicated possibilities but we won't think about that just now. You're not too far off having your 9k righted again. Good luck.
