iPod / MP3 aux in for 9-3
120939 Views 50 Replies 32 Participants Last post by  kielbasa
Hi,
I've just completed a project on the head unit of my 9-3 to provide an auxiliary audio input for my iPod. This is a variation on a couple of themes from this forum - you basically replace the audio signals from the head unit's CD player (I haven't seen instructions for this, hence my post).
You don't need to cut any wires or tracks, and the mod is completely reversible, though the soldering needs a steady hand ! In it's current form you insert any old CD in the player to get it going, but the iPod/MP3 player gets routed to the amplifier, not the CD (who cares if you can't play a CD - you've got them all on your iPod !). I have an idea for a dual-purpose mod, which doesn't need a switch, but haven't tried it yet.
Is anyone interested ? If so I can post instructions and pictures on a blog somewhere.
Cheers,
Nic
21 - 40 of 51 Posts
Just been mulling over what method to take, and had a thought on what could potentially be an easy way if you have the optional CD changer.
Once the signal to change to the external player has been sent via the HU, the HU is waiting for audio input from the external CD.
From an audio point this would be Ground L & R chanells.
Surley if you were to intercept the audio feeds, and put a switched socket, you could effectivly stop the music from the cd getting to the amp , and then feed
your MP3 output in via a stereo mini headphone plug.
This would also have the advantage that there would be no 74 minute pause, as the amp woudnt know when the end of a CD is reached.
You wouldnt be able to use the hands free controls to change tracks, but i guess thats a small price to pay
is it feasable
Mart
See less See more
Nic,
I like your post and method to bring the barge's (the 93) sound system up to date with an Ipod connector.
Being cautious, before i rip my radio into bits, your photo for step 8 appears to be adead link - any chance you could check it / repost that link please...
Nic,
Cheers[/b]
Hi,
Can't edit my original post - but all the photo's are in this photostream: http://www.flickr.com/photos/tynymynydd/se...57604515046331/
I think the URL for photo8 must've changed when I added the text overlay.
Happy Hacking!
Why not hardwire an FM transmitter?
You could fit something like those cheap transmitters (search ebay for FM transmitter) in the ashtray or centre consol, and simply hardwire to the car. You could locate a 3.5mm stereo jack to one of the free button blanks in the dash if you wanted to.
Surely that would be easier, and you'd not lose any existing functionality.
I have an FM transmitter so if i get the chance, I'll do this and let you know how it goes.
That'd work fine so long as you're not too fussed about the sound quality ;)
Even encoded at 256Kb/s + the signal's already gone thru enough mangling to get onto and out of your i-Pod/Mp3 Player. To then modulate it, Mux it transmit it, recieve it de-mux and demodulate it seems a bit harsh!!
(tongue firmly in cheek!)
At the end of the day - it's horses for courses - I'm a bit of a stickler for good sound quality (I can't tolerate MP3's coded at anything less than 196 Kb/sec for example) and I think it's worth the effort to maintain the purity of the signal. (If I could wire up my ageing turntable reliably into the car I probably would!!) I've tried FM transmitters and Cassette adaptors (uurgh!) in the past and have never been happy with them, So for me I'd prefer to do it this way. Full existing functionality is maintained - unplug the i-pod and the unit operates as normal.
The great thing about this thread is that there are now a variey of ways documneted and tested of achieving a result with varying degrees of complexity and functionality - so there shoudl be something for everyone.
See less See more
Can i suggest an easy fix - though it does mean an extra unit in the car. It's called a Pure Highway & what it does is so simple. It is actually a digital radio receiver & you put a small wire in the windscreen to pick up the digital radio, though that is very easy to do, but here's the clever bit, it takes the digital signal & broadcasts it to your analogue radio in your car & as it broadcasts from inside your car the signal is perfect, you just tune your radio to it. but one of the best things is that it has an aux input to plug in your mp3/ipod & it does the same with that - broadcasts it to your normal car stereo. It works i both my grand voyager & our little kangoo, though i must confess i haven't tried it in the saab yet - though i see no reason why it shouldn't.
bought it in argos for about £75 i think.
See less See more
You could of course just buy the lead that connects behind the dash and pay the £30 to have the computer recognise the input. about £70 in total.
Elkparts sell the lead for about £40.
No fuss, and no problems soldering/splicing/ no need to run a 74 minute blank cd/ can play CD's if still needed
This is what i'll be doing
where's the fun in that ? :grin:
anyway - I don't think that option applies to the 900/9-3 classic - otherwise there'd be no need for this thread!
My 2001 9-3 TiD has an FM modulator wired in. Its one of the ones that sits behind the dash and has hard connections to the aerial, stereo and 12v supply. The only thing visible is a power switch which I added to a blank switch on the dash, and I also hacked in a small LED indicator so I remember to turn it off. It plays through the radio on any of three switchable FM frequencies (just use an FM preset).
The input lead for my MP3 player headphone socket is wired into the bin on the centre console.
The FM modulator with all leads and power switch was about £20-25 on eBay a couple of years ago. Its worked great ever since I installed it and the sound quality is pretty good, i.e. better than FM radio.
Hi.
I have an 05 convertible that I wanted a better ipod connection in and a parrot. I have been trawling through many many pages on this and other forums looking for a solution. I went for a parrot MKi9200. I did not want to play through the front speakers only so I got a 't' harness off Ebay that connects into the EHU. The fibre optic cable and bus lines come out of the OE connector and plug into the new connector. The parrot lead plugs straight into the T harness and music comes out of all 7 speakers when using my phone or ipod. I did have to connect the yellow mute wire from the parrot into pin 4 of the 375 plug.
All in all I would say this took about 2 hours....mainly because I couldnt work out how to remove the EHU. Again, dead easy when you know how.
When I use the Parrot, the display shows 'telephone'.
The lead was £12 on ebayand the Parrot was £159 on ebay. THe parrot charges the ipod and it displays the ipod menus on a colour screen.
I hope this helps anyone with upgrading. Options are quite limited with upgrading and the saab ipod connection is pretty poor so if you want a quality ipod connection AND a parrot.....this is the surely the best route.
ps i am a newbie so please scuse any omissions or errors.
See less See more
hi every one, i am newbie and looking to install a parrot mki9200 on my 54 saab Aero convertible. I believe i have 7 speakers in my car and i want music to play through all speakers not just the front ones. Chubbs mentioned above that he bought a "t" harness from ebay to make it work. is there anyone who could tell me whats the actual name of "t" harness and how to connect it please? would i have to buy any additional harness or cables? what is this EHU??
please people forgive me if i sound daft and thanks in advance.
please people forgive me if i sound daft and thanks in advance.[/b]
Welcome to SS..
here is for early 9-3..
you need to be here>>>9-3 03 onwards
I have the exact same question.
I'm thinking it might be this one from ebay, however it says it only works for CK3000 and CK3001 and specifically states it only routes sound to the front speakers. Aside from that, it sounds exactly like what chubb is describing though (puzzled)
See less See more
Should be no problem with an FM modulator. Several people have installed them.
Some have used a similar one made by "Veba". Bought from ebay.
Hi,
The CD player in my car doesn't work.
It seems the disk isn't rotating anymore.
If I insert a disk there is some action but I can't hear it rotating.
After a minute or so the inserted disk comes out again.
I don't want to play disks anyway.
But I am wondering, would I be able to modify it to be used as an MP3 player?
It seems a bit silly to buy a new radio system only to disconnect the CD again.
Bypassing my broken player would be the ideal solution.
See less See more
I fitted a wired FM modulator to my 2002 convertible. The sound is miles better than the fm transmitter but not as good as a CD but thats no surprsie but it only cost about 35 quid all in. I still have the original stereo so it all looks right and..... best of all, I fitted it myself. If I can do it, anyone can....REALLY. It's got to be the best compromise of ease, quality of sound and price.
So I have a UK 2001 Saab 93 with the stock single CD in the dash. Similar to this:
http://www.familycar.com/RoadTests/Saab9-3/Images/Dash.jpg
I really want to add a line-in but my tinkering ability is pretty limited.
So FM Modulators seem like the best option for me. I have had a professional install quoted but are in the region of £150 so that’s out of the question.
There are a couple I have seen as possibilities for self install
http://www.ipodxxxxxxxxxxxxxx.co.uk/Connects2_iConnect-FM_iPod_Adapter
http://www.ipodxxxxxxxxxxxxxx.co.uk/Dension_ice>Link_FM_Modulator
The only thing I worry about is adding a power connection. Splicing and soldering wires scare the life out of me. However the two solutions linked above seem to suggest its easier than that. Can they just be wired in to the existing wiring harness and is that a relatively easy job?
If anyone has any experience in either of these products Id be really interested to hear how they went. Is one better than the other?
Thanks in advance everyone.
See less See more
Right scratch that. Seems the company I was linking to has a terrible reputation.
Done some more reading and hoping I can achieve what I want a bit cheaper.
Using a Connects2 system. Planning to use ScotchLoks to keep it simple.
Questions now are:
1. Will splicing in to the 'Ant Trig' wire work to power it? Assume that is the trigger for the motorised aerial so will turn on the modulator when radio is switched on.
2. Can I still use the radio and will there be any interference issues?
Any help much appreciated
Edit. If not which is the best wire to splice in to
http://www.flickr.com/photos/[email protected]/7247883394/
See less See more
21 - 40 of 51 Posts
