I'm sure a lot of you have the same problem, when i press the door mounted boot release i can hear the electric part of it working the mechanism, but as soon as i let go of the button i can hear it slot back into place.
I can use the button on the alarm keyring, which incidently, activates the mechanism then holds it for a couple of seconds before release. But i'd like to be able to use the internal button as well.
Any ideas?
Skiddins
I've never looked into exactly how they work, but I presume it should kick the boot up a fraction so that it doesn't lock back down. When I operate mine you can hear the motor wind back but it never locks the boot again unless you close it yourself.
HTH
Neil
is yours a hatch, or a cd. i have a 1990 cds, in which the boot release stopped working, i eventually traced it down to a break in a couple of wires in the rear loom that controls this function, and whilst i were repairing it, the same thing happened that youre describing. also are your pnuematic struts ok. hope this helps
