I've found the best way to remove the IC is thru the bottom. The plastic valences beneath the vehicle have to be removed, anyway, in order to remove the two lower screws that attach the AC condenser to the IC. Also, you wont have to remove the radiator or any of the hoses, although the radiator and oil cooler will have to be tipped backed towards the engine. This means that the front of the car should be placed up on jack stands, in order to have enough room to drop the IC down and out. However, this method will save a lot of time because you don't have to drain the cooling system, nor remove the oilcooler from the radiator. This method worked well for me when I replaced the stock IC with a 50 mm Kylar Jonsson. The trickiest bit is removing the bottom valence - the fasteners that hold it in place see a lot of salt, and hence, corrosion. It might be a good idea to stock-up on some new ones in advance.
