Yesterday my check engine light came on and flashed 3 times indicating the inlet air temp sensor.
When I measured the voltage across the sensor it was 1.58V, this was at a temperature of 10 deg C. I also measured the rersistance of the sensor and it was 3.0K Ohm so the question is whether these values seem correct?
The values in the Haynes book are 1.5V @ 40 deg and 2.4V @ 20 deg so the voltage does seem on the low side but then it also says they are 'approx' so I'm not sure if the sensor is OK.
I was going to just replace it but I've just been to my local dealer and they quoted me £52 for the sensor (Saab part no 9174442)!
