I've got a 9000 Aero which has been a lovely reliable and never had any problems to speak of. But now I'm a little worried. Got some funny noises from the gearbox (a weak point on these cars, I understand).
A little background, my gearbox has been sweet as a nut. Not a single problem usually associated with these cars. Easy to select every gear, never pops out, no funny noises. NOTHING. Until today.
When I drove my daughter to school this morning it was completely fine. And now, when I drove to the shops suddenly there was a weird noise and a vibration through the gear lever. It still selects every gear perfectly fine and when you're accelerating (even a little) there's no indication of any problem. The problem appears on overrun/engine braking. The second you let off the throttle there is a very audible and fast ticking/tapping/clicking kind of a noise accompanied by a pulsing vibration through the gear lever which is louder/faster with higher revs. What you feel is exactly the same as the noise so it's obviously connected to the gearbox somehow. Sounds almost a little like the old playing card in the bike spokes, but more muted. It can also be felt (but not as much) when the clutch pedel is pressed, and VERY slightly when the car is in neutral. There is no noise or vibration when the car is stationary with the engine running.
I've had enough experience to be very worried, but I'm slightly hopeful since nothing seems to actually be wrong with the functioning of the gearbox. The car drives as it always did. I'm fearing expensive gearbox repairs though. Do you have any thoughts on what this might be?
This is my only car and I've become quite attached to it and rely on it. Would be a shame to have to part with it.
Thanks for your time and consideration.
