1 - 16 of 16 Posts
My 9-5 auto has yet another niggly little problem - namely there's no backlight for the gear shift. Is this likely to be a blown fuse? If not, is it something a simpleton can fix?
Probably the bulb in the selector mechanism.
Buy one from Halfords or equivalent as the last time I got one from a dealer they were over £10.
Not overly involved to change but from memory a little fiddly. You pull up the rubber surround around the selector base then carefully prise up the plastic plate to access the bulb holder.
Hold on a sec!! Are you saying the P R N D 3 2 1 should light up?
Damn!! I thought that they weren't supposed to be lit. I've had mine for months and just assumed that was the case. :mad:
Mine is a 2002 or is it only the 2005 on that had it?
From MY03: green backlight with the selected position in yellow/amber. All models up to MY08 definitely have a "lightbox" fitted behind the selector window.
The things you learn on this site!
It's been annoying having to look at the gear position display on the instrument cluster in the dark mornings these past few months but I could not remember if my 2005 Vector ever had illumination by the gear shift. Had a look this morning and eventually found hidden under green and grey plastic strips a blown bulb!
New bulb cost £1-10 at the local A1 shop. All fixed now just in time for the brighter mornings!
New bulb cost £1-10 at the local A1 shop. All fixed now just in time for the brighter mornings![/b]
Snap!
I had no idea. Does anyone know what bulb is required?
Got this sorted today, quite an easy fix if a little fiddly to get the old bulb out of it's holder.
A quick 'How to' for anyone who is interested:
Start by removing the outer rubber trim (it just prises off)
Then gently lever up the inner part
This leaves you with the green tinted plastic bit which slides back and forward as you move the gear selector. This is easily removed.
Below that is the graduated tint so that the light shining through is uniform
Bulb is beneath that and is a bit of a pain to get out.
The finished result.
Well chuffed with it as I didn't think they were supposed to light up.
:thumbsup:
1 - 16 of 16 Posts
