Hello everyone,
I have got an idle problem with my Saab 9000 CSE 1993 2.0 (non-turbo). Basically I have got two problems that probably are due to one fault.
1) When idling after the engine has warmed up, especially when sitting in traffic, the engine idles nicely at around 1000rpm, but about every 30 seconds or so the engine drops the revs almost to the point of stalling and then brings it back up to the 1000.
2) I also have a random "Check Engine" light . This comes on randomly and does not seem to match the above problem and I cannot get the error code (flashes) out of the ECU because its so random when it appears.
I posted a while ago about the Check Engine light and someone suggested the IAC valve. I thought this could be the problem for both faults so I gave it a clean and a lubrication but it has not made any difference, Im not sure if it needs replacing. Does anyone have any idea what could cause this because I dont wany to buy a new IAC, if it turns out to be something else. Could it be a faulty sensor somewhere? Any help would be very greatfully recieved.
