Hi all, out in the saab today and all of a suddn there was no clutch peddle.. Pulled over and had a look underneath and the Hydrolic clutch pipe that goes along the bulk head to the gear box end has got a split in it where it goes from being a flexi braided to the metal bit. So put your foot on the clutch and you just get a spray of fluid...
Has anyone ever changed this. Looks reletivaly easy to change, so not too worried about that. I just wondered if I would have to bleed the clutch then, if so how..??
Thanks Anthony
Thankfully, I've never had to do this myself yet, but there's a good write-up here .
Bleeding is easy but you will need a pressure bleeder (Halfords) - or a vacuum bleeder (dearer).
Quasi has a procedure for that, too, here , but only use Dot 4 fluid.
