1 - 1 of 1 Posts
2004 9-3 2.0T Convertible Linear.
Every time I've seen how somebody had repaired there Amp 1 it's been by chiseling off the corrosion, replacing a bulgy capacitor or reflowing a cracked solder joint.
Being a 'vert the Amp one is up off the floor so it's sparkly clean inside with no bad capacitors and a careful inspection with a magnifying glass has revealed no cracked solder that I can see.
I read somewhere how someone fixed his by replacing the PAL001A transistor.
Mine looks good with solid solders and no scorch marks or smells.
So, how do you diagnose the problem?
1 - 1 of 1 Posts
