I concur with Ylee.
I don't want to sound alarmist, but how can fresh oil turn black straight after a change?
Obviously, there is immediate contamination of the fresh oil! But with what?
In my view, this situation must be caused by black sludge, due to a previous owner's lack of regular oil change and use of quality oil.
I would definately take rocker cover off and check area for signs of black sludge.
If this is the cause, then carefull consideration whether to use a engine oil flush (before changing oil again) is required. With some engines, a flush can cause sludge to block internal engine mesh filter (stops pieces of metal getting picked up by oil pump!), resulting in a nackered engine!
The only other cause I can think off, is that the old engine oil is not left long enough to drain properly (or car not standing on flat ground), resulting in old oil still in engine when sump plug replaced.
Hopefully, it's just the latter...
