...I like to think that it wasn't her fault. Here's the story. I get my baby back from service yesterday, they replaced the front brakes and the engine mounts. I have to store the car outside overnight, and it is BITTER cold. It was about -15F this morning when I started her up. She coughed and spat the first time, and the second time she turned over, but was idling funny. I think, "No problem, just the cold. She needs to warm up." So after classes I go start her up to head home and the same thing happens. (it is still cold out, maybe 4F tops!) I dismiss it as weather again, and rev the engine a bit to help her warm up. As I do so, I smell gasoline fumes in the cockpit
. I lift the hood to see what's up. This is what I found. When tugging on the throttle cable to simulate the reving I was just doing, I noticed a gas escaping from between the exhaust manifold and engine block on the Driver's (left) side.
again!. It appeared to me that one of the studs holding the exhaust manifold to the block was missing. To my further discomfort, this exhaust leak seemed to be in direct proportion to throttle input. Needless to say, I drove right to my dealer. How could they miss this one? Well, according to them, and I guess I trust em here, it was not a result of the procedure yesterday, as that was just the top corner of the block. They confirmed that it was a broken off stud on the manifold that was causing the leak. Unfortunately, they also said that it would probably be a four to six hour procedure to remove the manifold, grind out the remaining stud and replace it with a new one (at $72/hour, that isn't cheap! ) I asked him about the fumes, and he again confirmed my worst fears. That the untreated exhaust fumes can be vented into the passenger compartment through ACC, and there is CO as well as unburned gas in there, so driving it much could be dangerous to me, so I don't really have much choice other than to get this fixed quick! Have any of you ever had a similar problem? Any words of wisdom or advice would be GREATLY appreciated here!
