Hi All, Just had my gearbox changed and the Stereo is asking for a Code, I have the code but I don't have a drivers hand book,How do I do this? Any help greatly appreciated!
There's no code for a radio on a 9-5. It should be permanently linked to your car. You can take it out and replace it as many times as you want to. Has the dealer messed with it?
Thanks for the feed back, Ignore everything, the garage got my car mixed up with another he was doing which had an after market fitted stereo, Confused everyone with that!
I have a 2002 radio I put in a 1999 It says the radio is locked.
The 9-5 radios are married to the specific car using its VIN, you can't fit another 9-5 radio unless that radio has been divorced from the donor car and then married to your car. It is possible to divorce a radio if you just have the VIN from the donor car but otherwise it won't work.
Divorcing and marrying has to be done using a Tech2, so its a garage job. Its usually cheaper to fit an aftermarket radio.
