I have to change my rear right caliper thanks to a knackered bleed screw.
I can’t seem to get the hand brake cable out. I’ve disconnected the cable part from the caliper but the housing is stuck.
Anyone got any words of wisdom on getting it out?
Discussion Starter · #2 ·
Ended up cutting the cable after trying everything. The steel sleeve on the cable has corroded itself solidly to the caliper. Couldn’t even remove it when the caliper was off. Either way the it’s being traded in for another.
