Hi chaps
have a problem with the aero. Both the dash boost guage and the aux speedparts one have both stopped working
Nothing wrong with the turbo, no smoke, still whistles. So is this a vacuum leak or has a hose come off completely?
Also have noticed the Forge recirc dump valve is making a slightly different sound. When I checked under the bonnet there seems to be a slight leak from the area around the air intake.
Any ideas Would like to get this sorted quick as I'm off to the Ring Friday am.
cheers
Zahid
The dash boost gauge and dump valve are fed from the same take off point from the inlet manifold. It varies according to MY though.
Trace the hose back from the dump valve to the Y piece, and from there on to the manifold. It sounds like the hose might have popped off the manifold to me. If all looks good and there are no obvious hose splits, then it might be where you have plumbed in your aux gauge.
Thanks Mark. Wish I had a garage so I could have a go now I'll have to take the car to my mechanic tomorrow as I'm at work all day. Hopefully he can sort it
cheers
Zahid
