Cars just passed its MOT(1995,cse2.3lpt)whilst under going the test the tester noticed a small crack(5-10mm)where the sump plug fits weapping oil which needs welding found someone to weld it problem is i cant get to 1 of the torxs bolts... The car is on ramps on my drive and ive just spent 5hours on my back(no laughing)taken the undertray exhaust flywheel cover off got all but 1 bolt off the sump its the one hidden behind the the drivers side drive shaft i cant get a socket/ratchet/exstention bar/hand in or around it nothing fits the angle that the bolts at!!! has anyone taken the sump off and managed to get to that blasted bolt if you have how did you do it because ijust cant get it. Any help will be really apreciated.
