Having just received my Stage 1 upgrade, I am a little confused when fitting the APC.
I understand that I have to remove the pipe from the wastegate to compressor housing and connect them seperately to the APC but I am confused regarding the positioning of the pipe for the turbo intake pipe. The diagram is a little misleading!
I have attached a picture to see if it is the correct nipple (ooohh-eerrrr! )
i am a bit confused Scotty, are you fitting an APC upgrade (as in the computer that controls the turbo and such) or a MBC (manual boost controller)
the APC is generally a black box with a plug
it sounds to me, from your description with the intake pipes that you are installing a manual boost controller
also, what car do you drive? (sorry, i am not familiar)
