Just finished putting everything back together after changing the head gasket, timing chain, timing and balance chain guides, water pump and 5 hydraulic lifters on my Aero. I cleaned the throttle body (and turned the throttle stop screw) and AIC valve whilst it was apart and gave the wastegate rod a couple of turns up (i.e. increase base boost slightly) also changed the BPC valve as the old one was open circuit on one side and engine regularly hit overboost. Also fitted oil pressure sender for oil pressure gauge, new tensioner pulleys/belt and one valve between cam cover and inlet (old one was two way!)
Started her up (first time) and everything was OK apart from the idle control, went up to 3k, after a few minutes it would then hunt from 2k to 2.5k every second so I guess the ECU was trying to set the speed but was outside its parameters. There was NO check engine light. Playing with the throttle stop screw eventually got things controlling to 1100rpm. Came back after an hour and the idle was back to 3k, resistance across the AIC gave 7 ohms (right value). Problem was AIC as when I block it the idle speed was OK. I then fitted an AIC from a 91 2.0L turbo, different type of AIC but resistance across it was the same. Idle now controls without a problem. Drove 30miles last night, everything very good, no overboost, sweet. Then this morning I pull out of the drive – spun the wheels in second which surprised me, then check engine light comes on and has stayed on even after switching engine off for a couple of minutes. Car runs great though, idle OK, boost correct, a dream but now with check engine light, no hesitation.
Any ideas? Lambda sensor broke after removal refitting, why did old AIC valve give up after being cleaned. Has the AIC from the 91 upset the ECU? Can I pull the error codes or is it a dealer visit? Help.
