Hello folks.
I hope some of you wise heads may be able to help.
I have a 1991 900 SE, generally in sound condition apart from a sagging headlining and the occasional whiff of petrol and the following problems I would like to deal with:
The heater doesn't appear to work, but I suspect this is due to a broken heater control shaft (which I gather is quite common). Can this be changed without taking the dash out/apart? Any advice gratefully received.
Additionally, the temperature gauge stays firmly on Cold unless sitting stationary for a long period. I assume the thermostat is stuck in a fully open position. I would like to flush the cooling system so need to get the heater matrix open and change the thermostat at the same time.
I would be very grateful for any tips on how to best go about these jobs and if there is anything particularly 'Saaby' that I should be aware of!
Many thanks
Milodon
Many thanks
Milodon
