Yes they should,they should green,mind you there a bugger to replace,as you have to be very carefully prise the case off,then using a soldering gun melt the solder round about the bulb so it'll come out,then replace it.
I presume your seat swith is on the dash above the headlight level,all I do (again being carefull),is prise it out using a knife,its the only way I know,then do as described above.
Not an easy task,but worth it (i think) when you all your lights are working.
