Hi,
A little while ago I had a headlight bulb die, so I bought a new pair. Replaced the failed one, no problem, then decided to swap out the other one anyway. I took the bulb out ok (passenger side, with the battery a bit in the way) but cannot for the life of me get the new bulb in. Looking at both headlights, one has a metal ring thing, the other just has two glass lugs. (I know about the ex
tra piece of metal that fits to the bulb itself) so I am wondering if there should be a piece of metal fixed directly to the headlamp that side (as per the bulb I changed ok) or if it is supposed to be different. Or if the metal came out and got lost (maybe by a previous owner. Or.... something?!
I just cant figure this out. It is difficult to see well on the battery side which makes matters worse but I took photos of both sides and they are just totally different. Now I can't drive the car at night!
Here is the problem one...
And here is the good side...
They don't seem even a bit similar!
