This has been a bit topical due to benefit of h/L wipers at this time of year... anyway..:
I removed (quite easy job) R/H Headlight and wiper motor unit last weekend.
Using long/thin electrical screwdrivers (x2) and long nosed pliers, plastic lugs could be disassembled quite easily without significant damage, in order to split the two halves.
Apart from a lack of grease on the top rotor arm, there was no apparent fault with the unit. The internal spring clip make/brake contact arm was fine - with no evident lack of tension.
Unless the (amazingly!) small electric motor had burnt out, (prior to which it was intermittent - stopping wiper at all sorts of angles on H/lamp), I could not find anything wrong with the unit.
Unit still failed to work after a clean up and regrease.
Does anyone have any suggestions/clues?
I will ohm out connections with multi-meter when I get a moment.
Thanks in advance.
Thanks in advance.
