The brake pedal on my 9000 has gone very hard and my brake performance is far from good. Car was fine when I set out from home this morning but braking on the motorway it was pretty lousy.
No ABS lights on - light goes off in an acceptable length of time when I turn the ignition on. Servo seems to be working - if I work the pedal once I've turned the engine off I can here the vacuum pump working.
So any obvious things to look at?
Steve
On the journey home... OK during the 100+ minutes it took me to get past the NEC this evening the brakes went back to their normal behaviour.. So is it a vaccum problem or is it down to something like a sticky caliper?
Steve
