had some strange elec.problems recently.firstly pictogram shows rear bulb fault which i change,now when i put foot on brake pedal,front side lights come on also light on the dash to let you know lights are on.next when i switched off the ignition tonight and withdrew key the engine was still running.put key back in, turned the key on switched off..... still running,turned on again turned off lights,turned off ignition and the engine finally stopped.my acc which was blowing hot air is now blowing cold air and its just started snowing here......... sobs law.anyway the battery is reading 13.8 volt could this be related.
thanks to all who replied,it was one of the bulbs not seated properly,the bulb was working ok.but it must have been affecting the voltage i suppose,bloody sensitive beasties these saabs.thanks zep.
